Sign in or
LORDTEK |
Installation problem
Nov 20 2007, 7:32 AM EST
Hello,When I try to install soa, it give a error about swap file. I am using windows os not unix or linux based os. I can not install it for this reason. If you want to see the error the link is below. http://img261.imageshack.us/img261/2884/oracleerroroi1.gif Best Regards. 4 out of 10 found this valuable. Do you?
Keyword tags:
SOA BPM
cpyang |
1. RE: Installation problem
Nov 20 2007, 11:15 PM EST
Try increase your virtual memory.Control Panel -> System -> (Switch to Advanced Tab) -> Performance / Settings -> (Switch to Advanced Tab) -> Virtual memory / Change -> Setup paging file at chosen Drive. (Recommendation: Use custom size, set same amount for initial size and maximum size) 2 out of 3 found this valuable. Do you? |
LORDTEK |
2. RE: Installation problem
Nov 21 2007, 2:23 AM EST
Excuse me, but I have 2GB phisical RAM memory. I do not think that it needs to increase memory by virtual...However I will try. If the problem solved by your way then I will write... 0 out of 1 found this valuable. Do you? |
LORDTEK |
3. RE: Installation problem
Nov 21 2007, 2:43 AM EST
It is solved, thank you...
0
out of
Do you?
cpyang |
4. RE: Installation problem
Nov 21 2007, 4:42 AM EST
"Excuse me, but I have 2GB phisical RAM memory. I do not think that it needs to increase memory by virtual...Even if you have large physical memory, it's still necessary to have virtual memory on win32 platform. As many application will pre-allocate large portion of virtual memory on startup even if not require at the moment. Without paging space, all virtual memory allocation will occupy physical memory, locking them out of actual use. 1 out of 4 found this valuable. Do you? |
